Hi there,
I’ve been trying get the AX client deployed via SCCM 2007 using some switches off the setup command but have run into problems! We need the COM connector installed also and nothing I’ve read on the web has helped - I was hoping someone out there had any ideas on how to get this setup? Even just a push in the right direction would be helpful!
Thanks in advance.
