Hi everyone,
I have an issue with records insertion in NAV.
In my record, I need to do some control on a field called amount, if it is bigger than a certain value, an error message is and the user is called to modify the value of that field…
The problem is that NAV inserts the record anyway, with a zero for the amount field.
I want to be able to delete the records when the error message is raised…
How can I do that?
Thanks in advance
