How to deal with central installation
Hello, I have an installation with different country and I want to do it in a central way. 1. Do I need to deploy an axapta (app and db) per country or can I setup different company with different currency and language in one app and one db. 2. Can I launch such a “Gross Requierment Calculation” or MRP per company. 3. How can I share customer or product data between company. 4. I have almost 200 users (50 simultaneously) spread in the world over VPN should I prefer TS or CITRIX, does anybody have knowledge with AOS directly or TS or CITRIX ? 5. I have 200 users linked by Leased line, if I setup AOS and deploy 3 tiers thin is it available for workload (maybe 50-80 users simultaneously) Thanks you for the answers. Best regards
Hi Thierry, Regarding your first query - It depends on the countries that you are planning to implement. Let us assume that one of the country has localized application (ie application modified to match country specific functionality). In such a case, if you want to do a centralized implementation, you should merge the DIS layer between two applications. Regarding your third query - You have not mentioned about latency & ping time. But generally speaking, best way to set up an international system would be combining 3-tier with either Citrix or WTS. This way you would have best of the breed solution from both worlds. Regards, Harish Mohanbabu
