How to customize a form for a specific company
Hello guys!
I would like ti know if there is a way to customize a standard form for a specific company without affect the same form for other companies in the same AOS.
Thanks for the replies.
You can have a look on how is used UpdateDesign() method on forms and add a test with curext() method (returns company dataAreaId), you can also customize run() method. do you want to modify design or fonctionnality?
regards,
Thomas
Is there a method to modify the design and the functionality of the form without using code?
Thanks for your fast reply.
you can customize functionnality with security groups/profiles but it’s quite long and fastidious
