How to create report in Navision 2013?
Dear Friend.
i want to create a new report from item table in navision 2013. i can select 3 field in table 1 is description, 2 is thickness and other is weight. this is my table data that i use in report.
Color/Shade Thickness Weight
BRIGHT SILVER 0.05 5.71
BRIGHT SILVER 0.05 4.44
BRIGHT SILVER 0.08 5.71
BRIGHT SILVER 0.08 6.66
METALLIC SILVER 0.1 5.71
METALLIC SILVER 0.1 9.99
METALLIC SILVER 0.12 5.71
CHAMPAGNE SILVER 0.12 5.71
CHAMPAGNE SILVER 0.15 5.71
CHAMPAGNE GOLD 0.18 5.71
this is my report formate so plz help me to create the report …thickness come in header and weight come in body of report …
Color Description Thickness Thickness Thickness Thickness
Color Description 0.05 0.08 0.1 0.12
LT23B-2002(GREY) 5.17 5.71 3.0
LT12M-1002 3.99 3 6
BRUSHED 3 6
LT12M-2072 6
GA11T2LH-120607A 11.1 6
LT12M-0062
LT12M-2054 34
LT12M-3051 4 4
LT12M-6002 5 4
1111013A02 1
LT12M-3007
LT12M-0049 1 5 6
LT12M-1002 1 6 6
LT12M-2072 6 6 6
WD-009130A 6
WD-07931A 6
What you have tried till now ??
Where is the issue ??
Hi Sushant,
You need to set the BorderStyle property = None and then the BackgroundColor property in the cells in Visual Studio Report designer.
Hi Sushant,
Did you find a solution to you problem? If any of the suggestions helped you solved your question, then please click the “Verify Solution” on the answer that helped you, so that we can see the question is closed. Otherwise let us know how if there is something else wrong.
