how to create product in ax 2012 through code?
Hi every one,
I want to create a product through code in ax 2012?
can any one please provide me code for this, please…
hi nandini,
Try this code.
static void ProductCreate(Args _args)
EcoResProductService erProdSvc;
EcoResEcoResProduct EcoResProd;
EcoResEcoResProduct_Product_Master ProdMast;
EcoResEcoResProduct_Translation Translation;
EcoResEcoResProduct_Identifier Identifier;
EcoResEcoResProduct_ProductDimGroup ProdDimGroup;
//Initialize the service object
erProdSvc = EcoResProductService::construct();
EcoResProd = new EcoResEcoResProduct();
ProdMast = new EcoResEcoResProduct_Product_Master();
//ProdDimGroup = new EcoResEcoResProduct_ProductDimGroup();
//Newly created and initialize prodMast
ProdMast.parmDisplayProductNumber(“IDB-PM002”);
ProdMast.parmProductType(EcoResProductType::Item);
ProdMast.parmSearchName(“IDB Product Master 1”);
//Create a new translation object:
Translation = ProdMast.createTranslation().addNew();
Translation.parmDescription(“IDB product Master”);
Translation.parmLanguageId(“en-us”);
Translation.parmName(“IDB Product Master 1”);
Identifier = ProdMast.createIdentifier().addNew();
Identifier.parmProductNumber(“IDB-PM002”);
ProdDimGroup = ProdMast.createProductDimGroup().addNew();
ProdDimGroup.parmProduct(“IDB-PM001”);
ProdDimGroup.parmProductDimensionGroup(“Col”);
ProdMast.parmVariantConfigurationTechnology(EcoResVariantConfigurationTechnologyType::PredefinedVariants);
EcoResProd.createProduct().add(ProdMast);
erProdSvc.create(EcoResProd);
hi PVKrishnaiah,
Thanks for your valuable reply, but this code will create poduct master na… I want to create product only…
How can i do that?
Hi Nandini,
For creating distinct product, you need to use 'EcoResEcoResProduct_Product_Distinct class. Ex below -
//Create new Distinct product
prodDistinct = new EcoResEcoResProduct_Product_Distinct();
prodDistinct.parmDisplayProductNumber();
prodDistinct.parmProductType();
prodDistinct.parmSearchName();
Hi Harish,
Usine ur code I am getting this error “This document does not support the AxEcoResDistinctProduct class.”
Actually Harish I am very much new in AX, I just joined… So can you provide me a proper code please…
Thank you so much in advance…
This was utilizing the AIF, however it should get you started:
//Values have been grabbed, time to call AIF
//CREATE DISTINCT
if (productType == “Product” || productType == “Service”) // we have ourselves a distinct product
AxdEntity_Product_EcoResDistinctProduct productEntity = new AxdEntity_Product_EcoResDistinctProduct();
productEntity.DisplayProductNumber = productNumber;
productEntity.Identifier = new AxdEntity_Identifier[1];
productEntity.Identifier[0] = new AxdEntity_Identifier();
productEntity.Identifier[0].ProductNumber = productNumber;
if (itemType == “Item”)
productEntity.ProductType = AxdEnum_EcoResProductType.Item;
else
productEntity.ProductType = AxdEnum_EcoResProductType.Service;
productEntity.Translation = new AxdEntity_Translation[1];
productEntity.Translation[0] = new AxdEntity_Translation();
productEntity.Translation[0].LanguageId = “en-us”;
productEntity.Translation[0].Name = productName;
productEntity.SearchName = searchName;
productEntity.StorageDimGroup = new AxdEntity_StorageDimGroup[1]; // 11/29/2011 setting this on the released item
productEntity.StorageDimGroup[0] = new AxdEntity_StorageDimGroup();
productEntity.StorageDimGroup[0].Product = productNumber;
productEntity.StorageDimGroup[0].StorageDimensionGroup = prodStorageDim;
productEntity.TrackingDimGroup = new AxdEntity_TrackingDimGroup[1];
productEntity.TrackingDimGroup[0] = new AxdEntity_TrackingDimGroup();
productEntity.TrackingDimGroup[0].Product = productNumber;
productEntity.TrackingDimGroup[0].TrackingDimensionGroup = batchGrp;
AxdEcoResProduct productDocument = new AxdEcoResProduct();
productDocument.Product = new AxdEntity_Product_EcoResProduct[1];
productDocument.Product[0] = productEntity;
//service call
CallContext ctx = new CallContext();
ctx.Company = “inc”;
ctx.Language = “en-us”;
EcoResProductServiceClient prodServiceClient = new EcoResProductServiceClient();
EntityKey[] distinctKey = null;
if (productDocument == null)
MessageBox.Show(“BLAH”);
try
distinctKey = prodServiceClient.create(ctx, productDocument);
//MessageBox.Show("Successfully created " + searchName);
catch (Exception ex)
MessageBox.Show(ex.Message);
MessageBox.Show(productNumber + “Failed Creation.”);
errorList.Add(productNumber + “Failed Creation DISTINCT.”);
I am using this code for creating product in ax 2012. Product is creating finely but when I am going to release that product for any company on UI level then I am getting this error… "Cannot create a record in Item purchase order settings (InventItemPurchSetup). Dimension No.: AllBlank2. The record already exists."
and the code for creating product is :
static void Createp(Args _args)
BOM bom;
CompanyInfo companyinfo;
BOMTable bomtable;
BOMVersion bomversion;
InventDim inventdim;
InventTable inventtable;
tmpBOMinformation tmptable, tmptable1;
BOMConfigRoute bOMConfigRoute;
EcoResProductDisplayProductNumber _itemId;
EcoResProduct ecoResProduct; // Table
EcoResProductType itemType; // Item or Service
EcoResVariantConfigurationTechnologyType productType; // Predefined, constraint-based, rule-based
str _itemName;
EcoResEcoResProduct ecoResProd;
EcoResEcoResProduct_Product_Master prodMast;
EcoResEcoResProduct_Translation translation;
EcoResEcoResProduct_Identifier identifier;
EcoResEcoResProduct_ProductDimGroup prodDimGroup;
EcoResEcoResProduct_StorageDimGroup StorageDimGroup;
EcoResEcoResProduct_TrackingDimGroup TrackingDimGroup;
InventModelGroupItem inventmodelitemgroupitem;
EcoResDistinctProduct distinctProductTbl;
EcoResProductTranslation productTranslationTbl;
EcoResStorageDimensionGroup storageDimensionTbl;
EcoResStorageDimensionGroupProduct storageDimGroupProduct;
EcoResStorageDimensionGroupItem storageDimGroupItem;
EcoResTrackingDimensionGroup trackingDimensionTbl;
EcoResTrackingDimensionGroupProduct trackingDimGroupProduct;
EcoResTrackingDimensionGroupItem trackingDimGroupItem;
_itemId =“abc111”;
_ItemName = “abc111”;
distinctProductTbl.initValue();
distinctProductTbl.DisplayProductNumber = _ItemName;
distinctProductTbl.ProductType = EcoResProductType::Item;
distinctProductTbl.SearchName = _ItemName;
distinctProductTbl.doInsert();
productTranslationTbl.initValue();
productTranslationTbl.LanguageId = “en-us”;
productTranslationTbl.Description = _itemName;
productTranslationTbl.Name = _ItemName;
productTranslationTbl.Product = distinctProductTbl.RecId;
productTranslationTbl.doinsert();
if(storageDimensionTbl.RecId)
if(distinctProductTbl.RecId)
if(! EcoResStorageDimensionGroupProduct::findByProduct(distinctProductTbl.RecId))
storageDimGroupProduct.initValue();
storageDimGroupProduct.Product = distinctProductTbl.RecId;
storageDimGroupProduct.StorageDimensionGroup = storageDimensionTbl.RecId;
storageDimGroupProduct.insert();
if (! EcoResStorageDimensionGroupItem::findByItem(curext(), _itemId))
storageDimGroupItem.initValue();
storageDimGroupItem.ItemId = _itemId;
storageDimGroupItem.StorageDimensionGroup = storageDimensionTbl.RecId;
storageDimGroupItem.ItemDataAreaId = curext();
storageDimGroupItem.insert();
trackingDimensionTbl = EcoResTrackingDimensionGroup::findByDimensionGroupName(“con-dim”);
if(trackingDimensionTbl.RecId)
if(! EcoResTrackingDimensionGroupProduct::findByProduct(distinctProductTbl.RecId))
trackingDimGroupProduct.initValue();
trackingDimGroupProduct.Product = distinctProductTbl.RecId;
trackingDimGroupProduct.TrackingDimensionGroup = trackingDimensionTbl.RecId;
trackingDimGroupProduct.insert();
if (! EcoResTrackingDimensionGroupItem::findByItem(curext(), _itemId))
trackingDimGroupItem.initValue();
trackingDimGroupItem.ItemId = _itemId;
trackingDimGroupItem.TrackingDimensionGroup = trackingDimensionTbl.RecId;
trackingDimGroupItem.ItemDataAreaId = curext();
trackingDimGroupItem.insert();
info(“Item created”);
Hi ,
What should be the code for Releasing the product to multiple companies .
What shall be the update product code : to update all other fields except the product name ?
Hi Nandini ,chk the below code it will helpful
public container createProduct(str60 _product,
str60 _productname,
str60 _searchname,
str60 _arabicDesc,
str60 _desc,
str60 _color,
str60 _size,
str60 _style,
str60 _site,
str60 _warehouse,
Str60 _vendorId,
str60 _externalDesc,
str60 _countingGroup,
str60 _defaultReceipt,
str60 _defaultIssue,
str60 _defaultLocation,
str60 _productDimension,
str60 _sizeGrpId,
str60 _styleGrpId,
str60 _approveStatus,
str60 _category)
boolean isVariantExist = false;
InventDim inventDim;
InventDimCombination inventDimCombination;
container productDimensions,displayNumber,ret,sizeColorStyle;
EcoResDistinctProductVariant ecoResDistinctProductVariant;
EcoResProductVariantDimensionValue EcoResProductVariantDimensionValue;
RefRecId ecoResDistinctProductVariantRecId;
EcoResProductReleaseManagerBase releaseManager;
CompanyInfo companyInfo;
EcoResProductTranslation productTranslation;
RecId color,size,style;
Inventtable inventtable;
PdsVendorCheckItem vendorCheckItem;
EcoResCategory ecoResCategory;
RetailAttributesGlobalLookup retailAttributesGlobalLookup;
CreateProducMaster productMaste = new CreateProducMaster();
ttsBegin;
if(!EcoResProduct::findByDisplayProductNumber(_product).RecId)
ProdMast.parmDisplayProductNumber(_product);
ProdMast.parmSearchName(_searchname);
Translation.parmDescription(_desc);
Translation.parmLanguageId(‘en-us’);
Translation.parmName(_productname);
Identifier.parmProductNumber(_product);
ProdDimGroup.parmProduct(_product);
ProdDimGroup.parmProductDimensionGroup(_productDimension);
select * from ecoResCategory where ecoResCategory.Name == _category;
select * from retailAttributesGlobalLookup where retailAttributesGlobalLookup.Category == ecoResCategory.RecId;
sizeColorStyle = productMaste.insertProductDimension(_product,_color,_size,_style,retailAttributesGlobalLookup.VariantColorGroup
,retailAttributesGlobalLookup.VariantSizeGroup,retailAttributesGlobalLookup.VariantStyleGroup);
color = conPeek(sizeColorStyle,1);
size = conPeek(sizeColorStyle,2);
style = conPeek(sizeColorStyle,3);
if(!color)
_color = ‘’;
if(!size)
_size = ‘’;
if(!style)
_style =’’;
productDimensions = EcoResProductVariantDimValue::getDimensionValuesContainer(’’,_size,_color,_style);
//if(EcoResProductVariantManager::checkNotExistDistinctProductVariant(EcoResProduct::findByDisplayProductNumber(_product).RecId,
//productDimensions) && color && size && style)
if(!EcoResProductVariantManager::findDistinctProductVariant(EcoResProduct::findByDisplayProductNumber(_product).RecId, productDimensions).RecId && color && size && style)
ecoResDistinctProductVariant.DisplayProductNumber = EcoResProductNumberBuilderVariant::buildFromProductNumberAndDimensions(
_product,
productDimensions);
ecoResDistinctProductVariantRecId = EcoResProductVariantManager::createProductVariant(EcoResProduct::findByDisplayProductNumber(_product).RecId
,ecoResDistinctProductVariant.DisplayProductNumber,productDimensions);
if(!InventTable::find(_product).RecId)
EcoResProductReleaseManagerBase::releaseProduct(EcoResProduct::findByDisplayProductNumber(_product).RecId
,CompanyInfo::findDataArea(curext()).RecId);
select inventtable where inventtable.ItemId == _product;
if(inventtable)
inventtable.selectForUpdate(true);
inventtable.PdsVendorCheckItem = str2enum(vendorCheckItem,_approveStatus);
inventtable.doUpdate();
if(size && color && style)
inventDim.InventSizeId = _size;
inventDim.InventColorId = _color;
inventDim.InventStyleId = _style;
isVariantExist = true;
inventDim.InventSiteId = _site;
inventDim.InventLocationId = _warehouse;
inventDim = InventDim::findOrCreate(inventDim);
if(!InventDimCombination::find(_product,inventDim.InventDimId).RecId && ecoResDistinctProductVariantRecId)
// create InventDimCombination
inventDimCombination.DistinctProductVariant = ecoResDistinctProductVariantRecId;
inventDimCombination.ItemId = _product;
inventDimCombination.InventDimId = inventDim.InventDimId;
inventDimCombination.Insert();
ttsCommit;
ret = [inventDim.InventDimId,ecoResDistinctProductVariantRecId,isVariantExist];
return ret;
