How to create New Invent Report with Opening balance and closing balance for particular Item
I have one requirement in the 2009 Morphx report
we need to create the Inventory report which will have Opening Balance, Purchases(received), Sales (Issue) and Closing Balance. Report will be on Item Basis
there will be filtration criteria for the report on Physical Date basis where they will give from and to date.
As for example if From date is 1st December then for opening balance we will have the net(purchase minus sale) of all transactions which had happened prior to 1 stDecember i.e. till 30th November
The purchase and sale column will cover the transactions which had happened in that particular date range period.
For Closing Balance column it will be a calculation which will be like “Opening Balance + Purchases – Sales”.
can any one tell me which tables i need to take for this report … and which logic i need to add for the report and where ?
Mr. Vamshider,
It’s not only your responsible to just posting threads here.You must have to reply your threads.
You have been posting multiple threads and keeping on open without replying properly. That indicates you are wasting our time and your’s as well. Before posing some new threads first close the old one at least reply them.
Please be responsible…
Hi Mr Krishna ,
Still i am not get any solution for this … with out solution How can ?
Mr Vamshidher,
Have you checked your threads. I think we should have to reply the threads during discussion. Otherwise users who search for similar issues they won’t be comfort.
Here are some of your threads without your response. Neither you are replying nor making them verified solution.
http://dynamicsuser.net/forums/t/87500.aspx
http://dynamicsuser.net/forums/t/87502.aspx
http://dynamicsuser.net/forums/t/87494.aspx
http://dynamicsuser.net/forums/t/87408.aspx
