I need som help bout retail scheduler. I am trying to success about transferring datas fom pos to ax.
I created new job and doing the same thing with job p-0001 but when I ran the job, I got an error.
Error is saying: “There are no receivers defined for this job. Make sure that the locations included are members of valid distribution groups.”
How can i fix this?
Thanks.
I am seeing the same error. I will let you know if I find a solution, please do the same.
Tim
bee,
go to setup under the retail scheduleer Area open distribution groups and verfiy that location is a memeber of one for the distribution groups.
Distribution Groups>Groups> select group > subgroups verify your terminal is listed as a distribustion subgroup.
This solved the issue I was having.
Tim
