Hai Everyone, Good Morning
I want to create Batch class and for that i want to create a item … it was set it to run for every 5 min … what i want to do for this to create item in batch class and how to set it for run every 5 min
Hi Kavin,
Please create the batch class and schedule your batch job and set the recurrence.
Please refer the below links
http://msdn.microsoft.com/en-in/library/cc636647.aspx
http://dynamicsaxforum.blogspot.in/2013/08/create-and-execute-batch-job-ax-2012.html
Click the recurrence button in the dialog box batch tab and click recurrence button, then you can enter the 5 minutes recurrence in this section.
Hari
Hi Hariharan,
like this only i did in batch job form … In recurrence button i mention minutes but it was automatically change the minutes what ever i given means …
Hi Kavin,
Sorry, no idea. In my side AX 2012, recurrence is working fine. I can able to change the settings. Please try to recreate a batch job and try with new recurrence if it is possible.
Please refer this link for recurrence form http://technet.microsoft.com/en-us/library/aa616143.aspx
Hari
Hai hariharan ,
batch process working correctly after i enter the batch group and captions in recurrence i give no end date and give time for execute …
now in this continues i want to create number sequences for group item details … i write code for create number sequences in class run method … class executing but number sequence not creating … can you give some ideas for this
hi every one for creating an item in runbase batch class … i use this following code for create an item in batch class …
class Batch4DemoClass1 extends RunBaseBatch
InventTable inventTable;
InventTableModule inventTableModule;
InventItemLocation inventItemLocation;
NumberSeq numberSeq;
Description recipientEmail;
Notes emailBody;
Description subjectText;
Filename fileName;
Log log;
container con;
SysInfologEnumerator enum ;
public container pack()
return conNull();
public void run()
// The purpose of your job.
try
ttsbegin;
try
numberSeq = numberSeq::newGetNum(NumberSeqReference::findReference(typeid2extendedtypeid(typeid(ItemId))));
// numberSeq.num();
inventTable.ItemId = numberSeq.num();
inventTable.ItemId = “”;
inventTable.ItemName = “Onida”;
inventTable.ItemGroupId = “Television”;
inventTable.ModelGroupId = “FRP_PICK”;
inventTable.DimGroupId = “CF-W”;
inventTable.ItemType = ItemType::Item;
inventTable.ItemIdCompany = “”;
inventTable.insert();
inventItemLocation.ItemId = inventTable.ItemId;
inventItemLocation.InventDimId = InventDim::inventDimIdBlank();
inventItemLocation.insert();
inventTableModule.ItemId = inventTable.ItemId;
inventTableModule.Price = 1.00;
inventTableModule.UnitId= “Pcs”;
inventTableModule.ModuleType = ModuleInventPurchSales::Invent;
inventTableModule.insert();
inventTableModule.ModuleType = ModuleInventPurchSales::Purch;
inventTableModule.OverDeliveryPct= 0;
inventTableModule.UnderDeliveryPct= 100;
inventTableModule.ModuleType = ModuleInventPurchSales::Sales;
catch(Exception::Error)
this.sendMail();
catch(Exception::Info)
this.sendMail();
ttscommit;
catch
this.sendMail();
//This is the method for sending en email for Error or exception in adding new Records
//Passing the Value of Error from insertToFreeTextInvocie method
public void sendMail()
SmmOutlookEmail smmOutlookEmail = new SmmOutlookEmail();
recipientEmail = “@PER195”;
subjectText = “@PER196”;
// info( " hello world");
// error(‘Syntax Error’);
// error(‘Invalid Code’);
//info(error);
log = Info::infoCon2Str( infolog.copy(1,infolog.num()));
con = infolog.copy(1,infolog.num());
enum = SysInfologEnumerator::newData(con );
emailBody = “@PER194”;
while (enum.moveNext())
emailBody +=strfmt(’%1’, enum.currentMessage());
if (smmOutlookEmail.createMailItem())
smmOutlookEmail.addEMailRecipient(recipientEmail);
smmOutlookEmail.addSubject(subjectText);
// smmOutlookEmail.addFileAsAttachment(fileName);
smmOutlookEmail.addBodyText(emailBody);
smmOutlookEmail.sendEMail(smmSaveCopyOfEMail::No);
else
error("@PER197");
public static void main(Args args)
Batch4DemoClass1 batch;
use this code for create an ITEM in runbase batch class with Email info log for if number seq not creating … in run() if we comment means in form not creating a number seq so it send an info log to outlook attachment for what error showing and where it is like i mention this run() … i get solution for this and working sucessfully
// numberSeq.num();
// inventTable.ItemId = numberSeq.num();
// inventTable.ItemId = “”;
Hi hari haran thanks for your information … i get solution for creating a item in runbase batch class with error info log to email …
