How to create / compressan array during report run
Is it possible in Navision to create / modify an array length during report runtime.
Requirement
We run Navision with LS Retail, my requirement is as follows
  1. Go the Mix & Match Table, pickup a ref no.
  2. Go to the Mix & Match Line Table, count the number of records available for the M&M Table
Create an array/arrays for the same record count.
IF runtime creation is not possible, is there an option to delete empty array elements
As far as I know you can’t create an array or modify the lenght during runtime, you have to set the dimension of the variable when you declare the variable.
Why don’t you use a temporary table?
Regards
Claus
