I want to count no. of rows showing on list page according to the filters set by user
For example: By applying these filters I am getting 10 rows only however there are 180 rows without filters, so I want to return 10 only
Hi Aditya_raut,
I am doing this simply by adding the following code in Page Action/Button.
trigger OnAction()
var
num: Integer;
Customer: Record Customer;
begin
if Rec.FindSet() then begin
repeat
Rec.Sync := true;
Rec.Modify(true);
until Rec.Next() = 0;
num := Rec.Count();
Message('Selected Records: ’ + Format(num));
DisableSelect := false;
DisableunSelect := true;
end;
end;
Might this helps you.
Thanks this is working but I need to reduce manual work, actually I want it in factbox
