Hi Guys,
please help me with the following problem…
Suppose there is table A and table B…
table B contains 10 feilds
table A contains 3 feilds
what do i need to do in order to copy the record of the whole feild from table B to table A which has two feilds in common
Hi Tsunayoshi, welcome to Dynamics User Group. Unfortunately it’s not clear to me what’s the problem you need help with. Do you struggle with assigning field values, inserting records or what? What might help is showing pseudo-code of what you’re trying to achieve and pointing to the parts you’re unable to implement by yourself.
Also, please always mention your version of Dynamics AX. You can easily attach a tag with the version to your question.
