how to convert real numbers to text in ssrs report
hii all,
i use NumeralsToText() method in code, but can’t retrive value from the display method, how can i do it,
or
can i take value from textbox .
You can write the code in AX classes only and you can take the string field in SSRS report.
use num2str() and it takes 4 arguments.
Lalit can i use textbox value in NumeralsToText method
Can you precisely tell me what is your actual requirement ?
MY requirement is m having total amount field for e.g 1234 i want that total in word format in ssrs report
i.e "one thousand two hundred and thirty four " how this can b achieved in ssrs report only .
You search in google, you will find several code examples to convert numeric values into words in SSRS, form exam
http://sqlserver2005forum.blogspot.pt/2011/07/convert-number-to-words-in-ssrs.html
But I would but that logic in AOT and not in SSRS, since those functions are a core functionality and broadly tested.
Use Global class method to convert data from real to text
e.g: Global::numeralsToTxt(1234);
Nagaraj
