hi…
try this code…
- To write one new method in global class in AOT.
i.e)
static TempStr realToTxt(real _num)
int numOfPennies = (decround(frac(_num), 2) * 100) mod 100;
real test = _num - frac(_num);
int numOfTenths;
str 20 ones[19], tenths[9], hundreds, thousands, millions, billions, trillions;
int64 temp;
str 200 returntxt;
//number to text —
real fracnum=frac(_num);
real modOperator(real a1, real a2)
int tmpi;
real tmp1, tmp2;
tmp1 = a1 / a2;
tmpi = real2int(tmp1);
tmp2 = tmpi;
return (tmp1 - tmp2)*a2;
real checkPower(real _test, int64 _power)
int64 numOfPower;
if (_test >= _power)
numOfPower = _test div _power;
if (numOfPower >= 100)
temp = numOfPower div 100;
returntxt = returntxt + ’ ’ + ones[temp] + ’ ’ + hundreds;
numOfPower = numOfPower mod 100;
if (numOfPower >= 20)
temp = numOfPower div 10;
returntxt = returntxt + ’ ’ + tenths[temp];
numOfPower = numOfPower mod 10;
if (numOfPower >= 1)
returntxt = returntxt + ’ ’ + ones[numOfPower];
switch(_power)
case 1000000000000 :
returntxt = returntxt + ’ ’ + trillions;
_test = modOperator(_test, 1000000000000.00);
break;
case 1000000000 :
returntxt = returntxt + ’ ’ + billions;
_test = modOperator(_test, 1000000000);
break;
case 1000000 :
returntxt = returntxt + ’ ’ + millions;
_test = modOperator(_test, 1000000);
break;
case 1000 :
returntxt = returntxt + ’ ’ + thousands;
_test = modOperator(_test, 1000);
break;
case 100 :
returntxt = returntxt + ’ ’ + hundreds;
_test = modOperator(_test, 100);
break;
return _test;
ones[1] = “@SYS26620”;
ones[2] = “@SYS26621”;
ones[3] = “@SYS26622”;
ones[4] = “@SYS26626”;
ones[5] = “@SYS26627”;
ones[6] = “@SYS26628”;
ones[7] = “@SYS26629”;
ones[8] = “@SYS26630”;
ones[9] = “@SYS26631”;
ones[10] = “@SYS26632”;
ones[11] = “@SYS26633”;
ones[12] = “@SYS26634”;
ones[13] = “@SYS26635”;
ones[14] = “@SYS26636”;
ones[15] = “@SYS26637”;
ones[16] = “@SYS26638”;
ones[17] = “@SYS26639”;
ones[18] = “@SYS26640”;
ones[19] = “@SYS26641”;
tenths[1] = ‘Not used’;
tenths[2] = “@SYS26643”;
tenths[3] = “@SYS26644”;
tenths[4] = “@SYS26645”;
tenths[5] = “@SYS26646”;
tenths[6] = “@SYS26647”;
tenths[7] = “@SYS26648”;
tenths[8] = “@SYS26649”;
tenths[9] = “@SYS26650”;
hundreds = “@SYS26651”;
thousands = “@SYS26652”;
millions = “@SYS26653”;
billions = “@SYS26654”;
trillions = “@SYS101697”;
test = checkPower(test, 1000000000000);
test = checkPower(test, 1000000000);
test = checkPower(test, 1000000);
test = checkPower(test, 1000);
test = checkPower(test, 100);
if (test >= 20)
numOfTenths = test div 10;
returntxt = returntxt + ’ ’ + tenths[numofTenths];
numOfTenths = numOfTenths mod 10;
test = test mod 10;
if (test >= 1)
numOfTenths = real2int(test);
returntxt = returntxt + ’ ’ + ones[numOfTenths];
if (numOfPennies)
returntxt = returntxt + ’ ’ + “@SYS5534” + ’ cents ';
if(numOfPennies>=20)
numOfTenths=numOfPennies div 10;
numOfPennies = numOfPennies mod 10;
if (numOfPennies >= 1)
numOfTenths = real2int(numOfPennies);
returntxt = returntxt;
else
returntxt = returntxt ;
return returntxt;
- use this method …suppose to write job using this method…
static void TestNumeralsToTxt(Args _args)
AmountCur AmountCur;
str val;
AmountCur = 715.99;
val = realToTxt(AmountCur);
val = substr(val,5, strlen(val)-4);
print val;
pause;
- To get the correct output.
Thank You.
