How to concatenate fields in ssrs ax2012 reports?
Hi. I would like to conactenate invetdimprint and inventdimproduct fields within the report. How can I do this?
you can do it with an expression like this:
=Fields!invetdimprint.Value & " " & Fields!inventdimproduct .Value
(I left space between the values of both fields)
Janis
I tried doing that in salespackingslip report by creating a a new row but sadly it was blank.
Did you save the changes you made? Did you verify that changes were actually saved to AX AOT (the last change date/time for the SSRS report object)? Did you redeploy the report after that?
There is no reason why the expression mentioned above wouldn’t work.
I was not adding the solution to the AOT. Very dumb:) Thanks
