How to compare line by line
I am a beginner of Navision.
Now I am writing a report.
May I know how to compare the output line by line?
For example,
ID Field1 Field2 Field3
001 ABC DEF YES
001 ABC DEF NO
002 ABC DEF YES
if the same ID appear 2 lines, then the output should only show the line which Field3=NO
if the ID is appear 1 line, then the output should only show line which is Field3=YEW
Anybody cannot help me?I very URGENT. THANKS A LOT^^
Use a temporary table. Insert the details as per your condition into the temporary table. Make this temporary table as the source table for your report and print it.
Hi a,
I assume you’re using a report to show your data and that the dataitem is the table you mentioned above (Field 1, Field 2, etc.).
You can get the wanted result doing this:
  1. Create a variable pointing to the same table as your dataitem (MyTableVariable)
In the OnAfterGetRecord place this code:
MyTableVariable.setrange(ID,ID);
MyTableVariable.setrange(field1,field1);
MyTableVariable.setrange(field2,field2);
if mytablevariable.count > 1 then begin
if field3 = true then
currreport.skip;
end else
if field3 = false then
currreport.skip;
hope this helps,
cheers, Jan
[:)]Hi Jan Vorauer,
I solved it. Thanks a lot
