Hallo everybody, I’m very new in Navision.
I created 2 forms (a list and a card)
In each form I have a menu button and I can switch from the list to the chart and viceversa.
Now my question is: is it possible to close the actual form when I want to pass to the other?
At the moment when I switch from the card to the list the card form remains opened, I want to close it.
Thank you very much
Max
Welcome to DUG
Why do you need this behaviour?
How are you opening the card and list forms? via code or properies?
Hallo, I just open the card and the form via menu button (I created a new menu item with action runObject -->open the form).
Thank you Max
I tryed also to create a button with this c/ca code:
- OnPush()
CurrForm.CLOSE;
FORM.RUN(50002);
the form closed, but the other form (50002) doesn’t open.
I tryied also with RUNMODAL but it tells me that I cannot close the current form because it is blocked by the other.
Thank you Max
Instead of writing code use the property & on the push button write code currform.close.
I tried this on item card->Item Menu Button->List (OnPush).
List form opens & Item Card gets closed.
Try it.
Same Post in mibuso → http://www.mibuso.com/forum/viewtopic.php?f=23&t=57327&p=275858#p275858
thank you for your answer.
The problem is that I cannot understand where I have to use this & property?
Is there maybe a guide explaining that?
Thank you Max
Check the Standard Forms & their menu’s.
