I created a workflow for the “Purchase Requisition”, and submit it. through viewing the workflow history, I found that the status is pending,
Is there any graphic interface show which step is active at the moment, and also where i can find the workflow path that the workflow went through.
many thanks.
You can check those details in the Workflow history form itself. Refer below screen.
Go to AOT\Forms\Tutorial_Workflowprocessor and click Start for the workflow event to process or use batch processing.
Hi Kiran,
My workflow status is start but, not don’t have a sub-node called “Approval Started”. i do have a approval node there.
Have you run: Go to AOT\Forms\Tutorial_Workflowprocessor and click Start
Thanks Kiran, you make my life easier.
