How to check inventory records is get settled or not in Ax 2012.Can you suggest me the path to check the inventory settlements.
You can look at the transaction to check if they are open or not, value open field on inventory transaction will tell you that (in general tab)
You can go the closing and adjustments and see the related settlements (IM → Periodic)
Thank for ur reply
