How do you change the return status from Created to Open so I can run collection notes?
Hi …
The return status will change to ‘open’ after posting the item arrival journal as a result of starting the arrival overview
So what do I do in this process…
-Return order is entered
-Collection note needs to be printed (cannot find this anywhere in AX)
I cant run a collection note/delivery note off once tghe product has been returned as the collection note needs to go with the driver when the product is getting collected
Hi …
When you create the return order, there is an option to send / print the return order (on the action pane tab - send). Can this not be used as the ‘returns note’ ?
It could but it will not let me print off collection notes at the same time I print delivery notes :\
Thanks though think im going to have to request development
