I have asigned each user with different permissions. on a form, I want X user can not see a command button but other user can on the same form, my problem is in c/al code I can not change the command button’s property, can anyone suggest how to solve this problem. Thank you[V]
Hi here is one solution (HARDCODING!) Set the properties of the button: Name = MyButton Visible = False
**OnOpenForm**
If UserID = 'x'
Then CurrForm.MyButton.Visible:=True;
bye Andre
Hi Andre, Thank you very much, it’s work…!
