How to change Product type of Service Item to BOM
Dear all,
Please help to show me how to change Product type of service Item to BOM?
Thanks in advanced.
Service items cannot have a BOM.
That isn’t possible functionally.
It might be possible for a developer to make a change like that under certain circumstances. If you were to pursue a technical change, you would need to make sure that there are no open transactions for the item as well as ensuring there are no on-hand quantities (if the item is in a model group which is stocked).
Brent
Items of type service will not be having on hand.
Thank you for your answer Kranthi and Brent.
I understand that, but in this case we use the service as stocked product.
And now, we are using DMF to import service Item with Product type is BOM. It’s okay now.
Thank you alot for your answer Kranthi and Brent.
I understand that service item don’t have on-hand, but in this case we are using service as a stoked Item.
And now we are using DMF to import service Item with Product type is BOM.
This can help you,
http://blogs.msdn.com/b/dynamicsaxscm/archive/2011/06/01/service-products-in-dynamics-ax-2012.aspx
