I want to ask you all if it is possible that if we want to do any customization for a particular company, it will show the new changes in that particular company only and not in all other companies present in that Ax .
As if I am changing for eg- packing slip label in the design of purch table form to the label “Retrieve” then it is showing the changed name to all other companies also but I don’t want that .
Change the autodeclaration property of the control to Yes, to access that dynamically.
In the init(after super()) method have logic like this
if (curext() == ‘tst’)/// use swith if you want different labeks for different companies /// tst is the company
Inquiries.text(‘Test’); // Inquiries is the name of your control(which is button here)
