HOw to Change item dimension in production order -report as finished
It can’t change , because it read the lotID of production order line ,
Is Process manufacturing in report as finished enable me to change item dimesion to be as new item
Can you explain this more clearly? Is this the financial dimension or an item dimension, if so which one? If it is the batch ID then yes you can just select another, if you cannot then go to the dimension group and the batch number option and set the correct editing options.
