Hai to all,
Is there any option to cahnge the data type in the existing Fields?
I created a table with 4 fields,all are String fields.And i created a Form also by using this table.
Now i want to change the one Field in that table. i.e String to Enum.
is it possible?
Eliem
2
Go to design table and change the data type of the field that u want
Hai ,
Thanks for reply are u saying regarding to Data base?
but am asking in AX.
i found in that in data base but,if i change the data type in data base there is no effect to data type in Ax .
Thanks & Regards
Hai,
No idea about this issue?
kranthi
5
I don’t think you can do that - You need to create a new field.
Create new field of Data Type - String and write an update statement - and push all the enum values into the string field
and now delete the enum field.
Thanks For reply.upto first line i unsterstood.But i didn’t get the remaining.
could u plz explain breafly
kranthi
7
When you delete a field you will loss the data values in that field.
If you require the values - update the enum field values into our newly created string field and now delete the Enum field.
