How to change data simultaneously?
Hello, I am beginning to work with NAVISION and my question is the following one. How I can change the data of several clients simultaneously? for example, to change to several clients the warehouse code. Greetings.
Use Edit / Replace from Client Card.
what I mean is how simultaneously to update all data in warehouse code colum from clients table
If you select the field you want to change in an editable form, you can select the menu options edit / replace with, as an example “warehouse code”, the following information: - Search: <Almacen 1> - Replace with: <Almacen 2> - Match: - Replace full text: and then select the button “Replace All”
ok JSoage, it works! Thanks. Salu2
