Hello, I am beginning to work with NAVISION and my question is the following one. How I can change the data of several clients simultaneously? for example, to change to several clients the warehouse code. Greetings.
Hi, if you want to do this without coding then filter or mark the records that you want to change, activate the respective field, and select “Rename” from the “Edit” menu… This is the easiest way without coding. Saludos. Nils
Ok nilsm, it works! Thanks. Salu2.
