Hi AX guys,
Please refer to below screenshow. Do you know how I can change both names? Foe example, I want to change form name from “Titles” to “Offices” and column name from “Title” to “Office”. Any clue how to make it happen?
Ta
Hi AX guys,
Ta
In order to change the form name go to the design and right click on properties there will be field called caption make the changes over there
then as you have a tab for which you want to change the name in this case go to design>>tabs>>the tab in which you want to change the name>> right click on that >> there will be field called caption change the name…
and also the name for the dropdown like below
have you created any dropdown ??
we can go to particular dropdown and change the property
or else we can override the caption method and assign there a name…field in design also!!!
Yes i created the dropdown, but don’t know how to locate property of the dropdown.
