How to Cancel or Delete a invoiced PO in AX 2012? its urgent …I made some changes in AR parameters and i could delete Invoiced Sales Order, same i tried to AP parameters, I couldn find any,
I tried to put negative qty and amount and posted it. The qty has been deducted but the transaction is showing diff value…the amount I’ve mentioned was not deducted…it is showing some other value. y??
Depends what you put on the negative amount and how it was processed. You needed to mark it to the inbound really, or manually set the cost. Once posted you would need to apply the credit to the invoice in transaction matching.
You should make sure that you have all the information as it is like your original line…ex: taxes, Misc charges. Before posting I think you can check the inquiry> totals
