How to cancel a Transfer Order
Is there a way to cancel Transfer Order that i already posted and shiped? Thanks!
In NAV 2015
Hey Omni,
Check out this link if it helps you,
http://dynamicsuser.net/nav/f/105/t/
Thank you for your answer.
I didnt deleted the transfer order, I just sent it and now i want to cancel.
You say you didn’t delete the order it means you did partial shipment otherwise the order will be deleted by default. In any way i think there is no way to cancel the shipped and received order.You have two option:-Post new order with exact reverse to the first one or return the item to the original location using item reclassification journal and delete the first order.
Hope it helps
Hi [mention:8200b3e321be409fb0e96ee857708aeb:e9ed411860ed4f2ba0265705b8793d05] ,
Did Rock og Henri’s suggestion help you? If not, please let’s know whats wrong. If they did, then please click on the “This helped me” for the answers which helped you. Thanks.
