How to call SSRS report on Button clicked in AX
I am trying to develop SSRS report which is called when A button in form in pressed. I have created one Form showing data into grid and when particular row from that grid is selected and a button is pressed. I wanted to create one SSRS report showing selected row data. How can I do that.
Hi Sumit,
Just create a controller class and pass the ranges. Then create the report and create a new output menu item.
The same u can add it in the form.
Hope this helps u !!!
Madhan
Thank you Madan… I will follow your advice.
