How to call a SSRS report by code AX 2012
hello guys,
I created a new Desing in CustAccountStatementExt report and when I try to call it, It shows me the native design “Report”.
How can I call my new design??
My code:
static void job()
SrsReportRunController controller;
controller = new CustAccountStatementExtController();
controller.parmReportName(ssrsReportStr(CustAccountStatementExt,NewDesign));
controller.parmShowDialog(true);
controller.startOperation();
Pls Help me!!!
NOTE: I use “controller = new CustAccountsStatementExtController()” because I will send default params with
parmRDPContract() and parmQueryContracts().
It’s strange, because almost the same code is used by standard AX in CustAccountStatementExtController::main(). I assume the standard logic works for you, doesn’t it?
