Hello All NAV Developers,
We have a requirement where the user will put a string on each Item card and system should calculate the formula by replacing the actual value.
On Item1
Filed Name VALUE
FORMULA ELEMENT “(LxWxD)^2”
based on the actual values of L, W and D system should replace then and calculate the formula and assign it in a variable.
The above mentioned formulas will be different item to item so we need to have generic code to cater all the options.
Any suggestion on this will be highly appreciated.
