Hello Friends,
I have one table with two fields on click of button i can add the values into that table. I want to add new field into the table and then on click of button i want to generate a cheque number on the 3rd field i have added in the table. How can i do that ? In the form i have kept 2 edit textbox where i will give the starting cheque number and count is my another text box which will specify number of checks to be generated.
eg. cheque no is 1000 and count is 2
then in db i want 1001,1002,1003 as check number n rest other records the checknumber should be displayed as blank.
Next time when i give another parameters for cheque number and count then it should start after 1003 cheque number
