In ax 2009 I have form grid where it is display using query in form datasource init method, once the form opens on top I have a dateEdit field, when I select a date in the dateedit control my grid should get filtered like, if a particular field is empty in a record the range with date should not be applied but if the same field of a different record is not null the record should display only if its date field is less than dateedit range.
