i want to block backend access (AOT ACCESS) but also i need to give all permission in form kindly help me
Hi Rizwan,
You may get more replies, if you post in the AX forums. [;)]
Moved from NAV to AX.
Do you want user to “access of a single form” or “access of all forms of AX”? kindly elaborate your question.
You can have “all permissions” and " not all permissions" at once. It contradicts each other.
Maybe your goal is to give all privileges without assigning the user to System Administrator role.
yes i want give all permission without system administrator role
We already discussed this thread, on community Dynamics. Have a look at that thread.
Kindly note that it can bring performance degradation impacts.
If you want to add all privileges, just do it. What’s the problem?
there is any shortcut tat i can add all privileges without system admin,or i want to go each node and give full access accept system admin
System administrator is a role, not a privilege.
It seems that you should create a new role and all privileges there. Because privileges are grouped to duties, you can simplify it by adding duties, not privileges directly, to your new role.
