I was asked to create a small vb.net program for a client. If it were a mysql/sql database, this would be easy, but I am lost as to how to connect to the Navision databases.
I have installed the CODBC 3.70A driver, and attempted to create a connection, but cannot seem to do it. Ideally, I want to have the connection string in my .net code.
Is there any documentation on creating a connection string? I can use Odbc fine, I am just lost as to what needs to be done. Once the connection string is made and I get a good connection, i should be fine. I am trying to access the database at: \192.168.128.216\nav370\data\database.fdb
Btw, when I try to use the C/ODBC Setup in the ODBC Data Source Administrator, System DSN I get the error “The operating system cannot gain access to the file \192.168.128.216\nav370\data\database.fdb…” I currently have the share setup to READ Only.
The ODBC connection needs to be made via the Navision Server. Just like a client workstation. Only the Navision Server service has direct access to the data file. See the N/ODBC manual.
Well, giving the share Full Control for my user fixed the problem.
I occasionally when testing the connection though, get an error that says “The operating system cannot load the DLL module dbm.DLL” when I hit okay, get out of the setup, adn go back in, it works fine. This is an intermittent issue… any suggestions?
Where can I find the documentation on creating a connection string?
Well, ive done further investigation on connecting using vb.net and i have failed miserably. The more research I do, the more I learn that it isnt an easy task to complete. Does anyone have an example for connecting to Version 3.70A? The ODBC connections I make, keep giving me an error of: The driver doesn’t support the version of ODBC behavior that the application requested
This error occurs whether I run through Visual Studio 2005, or use the ODBC connection manager built into Windows. I am using the CODBC 3.70A drivers so I atleast know the versions are matching… it would appear that the communication between CODBC and ODBC.NET is where the problem exists.
