I am adding some fields in SalesInvoiceTmp Table and Syncronize the table. It gives one message The maximum buffer size is exceeded. So u create a new Table or increase the Table Buffer size in Ax server configuration. So I tried to increase the buffer size, but the field is disabled in congiguration(AX2012 Server Configuration>>Database Tuning>>Max Buffer Size). I dont know how to enable this. So I am also creating a new temp table, and adding some fields in this table and adding this table and fields thru RDP Class. I refresh the Dataset and the new fields, but it takes only one table fields (either old table or new table). How to get the total two table fields in RDP class.
Pls Help me.
Balu
