Hi expert ,
I want to Add/Update soap xml format multiple data of Customer / Item / Order . can you give me suggession which method i can use ? . Now i am using NAVISION service to Add/Update Customer / Item / Order .
Surajit
Hi expert ,
Surajit
i guess this link can help you.
Anil.
Hi anil ,
Thanks for the reply .But i have a XML data like below examle
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:ns1=“urn:Magento” xmlns:SOAP-ENC=“http://schemas.xmlsoap.org/soap/encoding/” xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” SOAP-ENV:encodingStyle=“http://schemas.xmlsoap.org/soap/encoding/”>
1
surajit kundu
<E_Mail xsi:type=“xsd:string”>surajitkundu2009@yahoo.com</E_Mail>
kolkatacb28
jalpaiguri
<Post_Code xsi:type=“xsd:string”>735213</Post_Code>
<Country_Region_Code xsi:type=“xsd:string”>US</Country_Region_Code>
<Phone_No xsi:type=“xsd:string”>973333333</Phone_No>
<Gen_Bus_Posting_Group xsi:type=“xsd:string”>EXPORT</Gen_Bus_Posting_Group>
<VAT_Bus_Posting_Group xsi:type=“xsd:string”>EXPORT</VAT_Bus_Posting_Group>
<Excise_Bus_Posting_Group xsi:type=“xsd:string”>GEN</Excise_Bus_Posting_Group>
1
surajit kundu
kolkatacb28
jalpaiguri
</ns1:CustomerListResponse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
in the above format what i need to be changed to add multiple customer data at a time (not one by one using) in NAVISION
Hi expert ,
please give a customer xml format data that i cam export that xml file through ‘CreateMultiple’ method service .
Surajit
Surajit,
could you please send me your object… that way i can have better look on this… and suggest a feasible solution depending on your code condition…
Because XML data creation is possible multiple ways… so i have no idea what kind of programming you are using to create xml files
Hi Anil,
I have a simple xml file data which i posted before .I don’t know which xml format data is supportted to push data in NAV.After that i will transform this XML file which format Navision is supported . I want to push xml data in NAVision using C# code. can you give suggession which method of Dynamics NAV i can use ?
Surajit
You need to customize a new object in dynamics nav to receive your data… no ready made code available in NAV…
Anil.
Hi all ,
i have done it using webclient.
I want whole setup from installation to configuration of NAV 2013 with my web shop using Magento Connector. So that My items from NAV can be display on my web shop. and it should be completely synchronized.
waiting for your reply.
Thank you.
regards,
Sangram
Hi Anil,
Thank you.
regards,
Sangram
