I want add Name field from table item into movement issue form. I’m right click into set up. it have not this field. Thank you.
Please mention the Version of AX.
AX2009. Thank you.
ItemName is not a field in journal transactions table (InventJournalTrans).
There is a display method on inventJournalTrans, \Data Dictionary\Tables\InventJournalTrans\Methods\itemName
You can add that to the form. That would not be a difficult task if you have some development experience.
Thank you, Kranthi. But, I have a little experience for ax. Please show me about that.
Karntai, thank you very much. I’m do it already.
