How to add multiple filters with not in condition ?
Hi expert,
I want add multiple filters . For example i have a Item2 table in my database(SQL Database) in which i have add item from NAV item table now i want to list of item from Item table which are not in Item2 table and another filter is ‘Item Category Code value’ . How i can able to add two filters one normal filter and another is not in filter ?
Please help .
Surajit
Are you using a SQL View?
What is the SQL Query statement you have now?
Are you trying in sql or navision???
How about throwing a quick flowfield in the item table
Exist(Item2 WHERE (Item2_No=FIELD(No.)))
unless you want a report?
if item2.GET(Item"no.")
then do something
else do something else
Now I am using Navision filter .example :
Item_Binding oNavBindingItem= new Item_Binding();
List< Item_Filter> filterArray Item = new List< Item_Filter>();
Item_Filter ItemFilter = new Item_Filter();
Item.Field = Item_Fields.IsTrue;
ItemFilter.Criteria = ‘True’;
filterArray Item.Add( ItemFilter);
oNavBindingItem.UseDefaultCredentials = true;
Insync_ Item[] list = oNavBindingItem.ReadMultiple(filterArray Item.ToArray(), null, 10000);
I have another SQL database where i added Item2 table now i want to list of items from Navision item table which are not in Item2 table in my databse. What will be best solution for these ?
Surajit
