Hello, can anyone give me an idea on how to write the code to insert image to existing record in job. For example, I have table A with the records inside. I want to add image to each record. Instead of inserting one by one on the form but I want to run a job to add image at one go since there are many records. I know how to write job to update data but how can i do it for image.
and how can I change in code the path of an image in a report (it depends on a value from a table to use the one ot another image).
Is it possible to write somethong like
if (feld1 == value1)
thisreport.image.path = “C:\path\x.png”
