How to ADD date to date ?
hi
I have field1 date I want when I choose the date in this field1 another field2 = field1 + 2 years
exemple :
fild1 = 15/09/2010
field2 = field1 + 2 years so
field2 = 15/09/2012 for exemple
some one can help me ?
thank you
You have a sys function called mkdate() that allow you to create a date based on fixed numbers. The parameters fo that funcion are : day, month and year number.
So you can use this to create your second date . The function mthofyr() gets the current month of a date, dayofmth() gets the day of a date and year gets a year number of a date.
If you want to sum then both, you can then use the function date2num(field 1) +date2num(field2) (this function gets the number of days so you need to prepare the second date before doing so as explained in the previous step)
and finally you revert the number of days to your date with num2date(the previous sum) .
Hi hakim,
if you want directly u can also add days
15/09/2010+730 it gives 15/09/2012.
thank you
the two methods are good
thank you
Hi Hakim,
You can also make use of “datemthfwd” method in global class
Hi
Which version of AX are you using? I’ve been unable to complete simple formula’s on date fields using the + days feature.
A vendor consultant indicated that is might have been available in a version different to what we are using.
Thanks, Meghan
