How to add a subrole to a role [AX 2012]
I couldn’t do it from “Assign users to roles” form, I could only add privileges and duties to roles.
I know how to add it from AOT but this way fields ValidTo and ValidFrom are empty. So there has to be a way to do it with valid dates.
It seems that you already have another thread about the same thing: How to add a subrole to a role and fill in ValidFrom and ValidTo fields [AX 2012].
If you don’t agree it’s a duplicate, please make the difference more obvious. Otherwise please continue the discussion there and I’ll lock this thread.
By the way, use dedicated tags (e.g. AX 2012) instead of adding them to titles (e.g. [AX 2012] in this thread title).
This is in Dynamics AX End User Forum so I was expecting an answer from the users with functional knowledge. The thread that you mentioned was intended more for developers rather than consultants.
I’ll use the tags when creating threads, thanks for your remark.
