How the Sales Order will Be Deleted after posting
I have a small Doubt,
When I post the Sales Order, i.e … Both Ship and Invoice.
The sales Order is Deleting. automatically.
Jus i would like to see when and by which functions it is called and Deleted.
I debugged many times, but… It is going on… that’s why i posted this…
Codeunit 80 has a HUGE sblock of code that starts with “WITH SalesHeader DO BEGIN”. In there, many pages down, you will find a statement “DELETE”, that’s where the header is deleted. The lines and other related records are deleted elsewhere. Start debugging the process, and when you jump into codeunit 80, set a breakpoint near the statement that says “// Modify/delete sales header and sales lines”, that’s where the process of cleaning starts.
To make things a bit easier you may also follow, in codeunit 80, the adventures of a boolean field called EverythingInvoiced - look at where and when its status is changed and where it is tested.
Hi Denstar and Anna Perotti,
Thanks for the Reply. It is very Helpful for me.
