How testpage and record works
1st Doubt:-
There is one field for which I set value like this
Testpagename.openedit();
Testpagename.fieldname.setvalue(10);
Testpagename.close();
Now in ui when I modify the value then it ask for confirmation but when I try using the code then it doesn’t ask the confirmation. I tried using the following code:-
Testpagename.fieldname.setvalue(12);
2nd Doubt:-
On ui if I assign same value then it gives me error but I can’t handle that error. My code is :-
Recordname.init();
Recordname.validate(fieldname, 12);
Recordname.insert(true);
It gives an error but when u try to handle that error then it says no error found inside asserterror statement.
