How should I fill a field in a form automatically with the same value that I fill another field in the same form
Can anyone help me with the code that I should write if I want to enter a value in a field in the General Journal form (External Document No.) at the moment when I enter a certain value Applies-to Doc. No. field. I have tried adding code in Applies-to Doc. No. - On Lookup trigger in Gen Journal Table but it didn’t work.
Thanks a lot.
Hi Magdalena,
You should use the OnValidate trigger.
hi Magdalena,
Exactly Wat dave said…
u should place the code on onvalidate trigger of that field.
Dave & Ravi
Thanks a lot .
Glad to Help [:D]
Is this the right code?
Applies-to Doc No. - OnValidate
VALIDATE(“External Document No.”,“Applies-to Doc. No.”);
Yes
