I am a beginner in developing in Microsoft Dynamic Nav. The version I am using is Microsoft Dynamic nav 5.0.
I have problem with calculating the sum per page for some decimal fields in a report. I have no idea of how sum per page can be calculated in a report. I have tried and I can calculate only progressive sum. Please help me
The standard way to solve this is to use the CurrReport.CREATETOTALS command to keep a running total and then place the variable in the TransFooter/TransHeader sections. Have a look at the standard invoices (report 206) for an example.
I tried this method but this printed progressive sum, not sum per each page, because what I want is the sum in every page, so for the values that are in only that page. This will be repeated for each of them. Could you please help me.
If I use the first method that you recomended me that was “Use the progressive total and save the value on each page and substract from the progressive total”, could you please tell me what is the code that I should write for this purpose because the save value property for the textbox does not exist and I have no request form for the report that I am modifying.
