How requistion sheet work
Hi
I first time using the Requistion Worksheet in Navision 2009, i have made an Sales Order now i just wana to call that sales Order from requistion worksheet (function → Special Order → GetSales Order)
but while doing this an error is coming “there are no sales line to retrieve”
can any one have any idea why this problem is occuring.
thanks in advance
shailesh
How have you marked the sales order as a special order?
yes , i marked the sales order as a special Order ( in Sales Line)
By ticking the box or setting the appropriate purchasing code?
by ticking the box
Use a purchasing code set with special order and see if this works from the requisition worksheet. Those line tick boxes should be set by the purchasing code, not by the user from memory.
its working
Thanks a lot Adamroue
for ur help
shailesh
