In my Form, i have one Chenckbox. Initial Stage , it must be a non editable one. after doing some operation, it should be change into editable one. For this functionality, where and how do this coding?
smiley [:)][:)]
smiley [:)][:)]
When opening the form - check the condition whether the operation is completed or not and enable/disable it.
write a method in the form
void enableFields()
Boolean enableMyField = false;
if (condition satisfied)
enableMyField = true;
Table_ds.object(fieldnum(Table,YourField)).enabled(enableMyField);
Call this method in init method of the Form Data source and after completion of your process…
Hi Kranthi,
Thanks for ur coding … it’s working now…
REgards,
smiley
